elenco codici errore ariston
chifadasefapertre
Messaggio da chifadasefapertre »
spero di farvi cosa gradita con questi codici errori della ariston recuperati dal sito:
http://www.hotpointservice.co.uk/hs/pag ... RROR_CODES
Hotpoint Washing Machines and Washer Dryers
* F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
* F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
* F12 - No mixed fill. It is likely that the water is not turned on at the taps.
* F13 - Check the water supply, inlet valve and hot and cold hose connections.
* F14 - A fault with the water heating has occurred. Book a service engineer
* F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
* F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer.
* F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
* F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a service engineer.
* F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
* F40 - Water below protection level during a heat step. Book a service engineer.
* F41 - Water level detect sequence incorrect. Book a service engineer.
* F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a service engineer to re-programme your product.
Fault codes for Hotpoint LCD EVO1 Washing Machines and Washer Dryers
* F01 - Short circuit motor triac - Book a service engineer.
* F02 - Motor jammed tacho detached - Book a service engineer.
* F03 - Wash thermistor open/short circuit - Book a service engineer.
* F04 - Pressure switch jammed on empty - Book a service engineer.
* F05 - Pressure switch jammed on full - Book a service engineer.
* F06 - Program selector error - Book a service engineer.
* F07 - Heater relay stuck - Book a service engineer.
* F08 - Heater relay cannot be activated - Book a service engineer.
* F09 - Incompatible eeprom - Book a service engineer.
* F10 - Pressure switch not sensing correctly - Book a service engineer.
* F11 - Pump cannot be activated - Book a service engineer.
* F12 - Communication error - Book a service engineer.
* F13 - Dryer fan or dryer thermisotor faulty - Book a service engineer.
* F14 - Dryer element faulty - Book a service engineer.
* F15 - Dryer element relay faulty - Book a service engineer.
* H20 - Not fillings. Check tap, hose and inlet valves
* LOCKED - Check interlock - Book a service engineer.
Fault codes for Hotpoint LCD EVO2 and V4 Washing Machines and Washer Dryers
* F01 - Motor traic short circuit - Book a service engineer.
* F02 - Motor jammed or tacho detached - Book a service engineer.
* F05 - Pressure switch jammed on full - Check pump for blackages.
* F08 - Heater relay stuck - Book a service engineer.
* F09 - Setup error - Book a service engineer.
* F10 - Pressure switch not sensing - Book a service engineer.
* F12 - No communication between cards - Book a service engineer.
* F13 - Drying thermistor open/short circuit - Book a service engineer.
* F14 - Drying element faulty - Book a service engineer.
* F15 - Dryer element relay fault - Book a service engineer.
* F17 - Interlock error - Book a service engineer.
* F18 - Communication error - Book a service engineer.
* H20 - Not filling. Check tap, hose and inlet valves
Hotpoint Fridges
* F1 - Freezer thermistor open circuit. Book a service engineer.
* F2 - Freezer thermistor short circuit. Book a service engineer.
* F3 - Fridge thermistor open circuit. Book a service engineer.
* F4 - Fridge thermistor short circuit. Book a service engineer.
* F7 - Evaporator thermistor open circuit. Book a service engineer.
* F8 - Evaporator thermistor short circuit. Book a service engineer.
* F9 - Temperature set switch open circuit Book a service engineer.
* FA - No feedback from Baffle Book a service engineer.
* FB - Fridge Baffle motor operating continuously. Book a service engineer.
* FE - Defrost time out. Book a service engineer.
Hotpoint Dishwashers
* F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
* F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
* F20 - Temperature under range. Book a service engineer. .
* F21 - Temperature over range. Book a service engineer.
Fault codes for Hotpoint LCD Dishwasher Models
* A01 - Float switch operated - Book a service engineer.
* A02 - Open/Short circuit heater relay - Book a service engineer.
* A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then Book a service engineer if problem persists.
* A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
* A05 - Pressure switch has not been reset - Book a service engineer.
* A07 - Open/Short circuit wash motor triac - Book a service engineer.
* A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
* A09 - Open/Short circuit with main wash traic - Book a service engineer.
* A10 - Open/Short circuit fill valve traic - Book a service engineer.
* A11 - Half load valve traic or alternating motor action - Book a service engineer.
* A12 - Open circuit heater rely - Book a service engineer.
* A13 - Open/Short circuit dispenser traic - Book a service engineer.
* A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
* H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
* F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
* F2 - Thermistor or sensing circuit failure. Book a service engineer.
* F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage.
Fault codes for Hotpoint LCD Tumble Dryers
* F01 - Short circuit motor traic - Book a service engineer.
* F02 - Motor jammed or fan blocked - Book a service engineer.
* F03 - Front thermistor open/short circuit - Book a service engineer.
* F04 - No pump piloting - Book a service engineer.
* F05 - No feedback from the pump - Book a service engineer.
* F08 - Static heater relay with contact welded closed - Book a service engineer.
* F09 - Eeprom is not programmed or not functioning - Book a service engineer.
* F10 - Common of heater open or one shot open - Book a service engineer.
* F11 - No pump connection - Book a service engineer.
* F12 - Communication error between boards - Book a service engineer.
* F13 - Rear thermistor open/short circuit - Book a service engineer.
* F15 - Dynamic heater relay with contact welded closed - Book a service engineer.
* F-17 - Master relay welded closed - Book a service engineer.
Thank you very Grazie :D
Molto interesante (ed utle)
gobbo74
peccato
Messaggio da gobbo74 »
Peccato perchè io ho un ariston LSI 67 duo e non ho il display ma solo dei led.
Sarebbero stati utili :oops:
giaguaroaquila
Messaggio da giaguaroaquila »
é veramente utile, peccato che io ho una Margheerita 2000 mod al89x con i led peciò nulla di fatto. Se sai dove trovare quelli x il mio modello mi faresti un grandissimo faore. Grazie
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
GIAGUAROAQUILA
Angelo74
Messaggio da Angelo74 »
Ringrazio il forum ed i suoi utenti..... ancora una volta ho trovato quello che cercavo !!!! :-)
Angelo
